19 years agoconfiguration controller in custom board
Hi! Everyone! Is it necessary to design configuration controller in custom board? If it just give stablity to system, is it mandatory or optional? Thanks! Regards http://forum.ni...
19 years ago --- Quote Start --- originally posted by jaeper+jan 28 2007, 05:27 pm--><div class='quotetop'>quote (jaeper @ jan 28 2007, 05:27 pm)</div>
--- quote start ---
<!--quotebegin-slacker@Jan 27 2007, 01:37 AM if you want the board/system to boot into a functional state then, yes, some sort of config controller (epcs, epc, etc.) is necessary.
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=20905)
--- quote end ---
--- Quote End --- Oh my 'nios' GOD. http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/biggrin.gif Thanks! very helpful! <div align='right'><{post_snapback}> (index.php?act=findpost&pid=20972)</div> [/b] --- Quote End --- Please keep in mind that you still need to load a hardware image from that CFI flash into your FPGA on power up. For that, you'll likely need a PLD. A lot of the Nios II Altera development kits use a "Max + Flash" combination and the config controller design is shipped with the Nios II EDS. I recommend this solution highly... Cheers, - slacker
