Compatibility with Quartus 5.1 and Nios 5.1
I'm a newbie and I'm wondering if the nios1.4 uclinux package can be used on a 2C35 Cyclone II device with Quartus v5.1 and Nios II v5.1 since the pdf hardware/software requirements doesn't include that device or those versions of the software. If not, are there any workarounds to get uclinux on the board? Thanks! Shindou9 Replies
Hi Shindou,
You should try out buildroot and work on Linux, follow http://forum.niosforum.com/forum/index.php?showtopic=3174 (http://forum.niosforum.com/forum/index.php?showtopic=3174) The tools are independent of chips, boards, quartus2 and nios2 version. - Altera_Forum
Hi hippo,
Running ./build0207 for setting up the toolchain and getting the following error. I'm using gcc version 3.2.3 20030502 (Red Hat Linux 3.2.3-47.fc4) cp/call.o cp/decl.o cp/expr.o cp/pt.o cp/typeck2.o cp/class.o cp/decl2.o cp/error.o cp/lex.o cp/parser.o cp/ptree.o cp/rtti.o cp/typeck.o cp/cvt.o cp/except.o cp/friend.o cp/init.o cp/method.o cp/search.o cp/semantics.o cp/tree.o cp/repo.o cp/dump.o cp/optimize.o cp/mangle.o cp/cp-lang.o cp/name-lookup.o cp/cxx-pretty-print.o attribs.o c-common.o c-format.o c-pragma.o c-semantics.o c-lex.o c-dump.o c-pretty-print.o c-opts.o c-pch.o c-incpath.o cppdefault.o c-ppoutput.o c-cppbuiltin.o prefix.o main.o libbackend.a libcpp.a ../libiberty/libiberty.a collect2: ld returned 1 exit status make[2]: *** [cc1plus] Error 1 make[2]: Leaving directory `/home/Ricky/buildroot/toolchain_build_nios2/gcc-3.4.5-final/gcc' make[1]: *** [all-gcc] Error 2 make[1]: Leaving directory `/home/Ricky/buildroot/toolchain_build_nios2/gcc-3.4.5-final' make: *** [/home/Ricky/buildroot/toolchain_build_nios2/gcc-3.4.5-final/.compiled] Error 2 Do you know what this error means? - Altera_Forum
It is building gcc in pass2. Please try, cd ~/buildroot, make menuconfig, toolchian option, disable c++, and make again.
You should select development tools packages when installing Fedora, and run "yum update" after installation.
thanks hippo,
Regarding step 5 - cd ~/linux-2.6.x# generate nios2_system.h from ptf make ARCH=nios2nommu CROSS_COMPILE=nios2-linux-uclibc- hwselect SYSPTF=your_system.ptf# config the kernel make ARCH=nios2nommu CROSS_COMPILE=nios2-linux-uclibc- menuconfig# compile the kernel make ARCH=nios2nommu CROSS_COMPILE=nios2-linux-uclibc- since the board is a 2C35, what should be used for your_system.ptf? will a linux_1C20 suffice? thanks again! - Altera_Forum
The ptf is generated by the sopc builder.
It is used by hwselect perl script to generate the memory map, io ports address and irq number for nios2 uClinux. It must match your hardware. If you use altera dev board, you should find it in your kits, (eg altera/kits/nios2/components/altera_nios_dev_board_cyclone_2c35/system/...). Or if it is a custom board, built it with the minimal components as in the guide. - Altera_Forum
Found it thx, though when I ran the make hwselect with the following options, I got the error below. I got a similar error when doing the make with the payload buffer and I think you mentioned in another thread to not use ROM?
Any modifications to the asm-offsets.c file needed? (line 149 btw looks like: DEFINE(LINUX_SDRAM_START, nasys_program_mem); DEFINE(LINUX_SDRAM_END, nasys_program_mem_end); ) --- Please select which CPU you wish to build the kernel against: (1) cpu_0 - Class: altera_nios2 Type: e Version: 1.0 Selection: 1 --- Please select a device to upload the kernel to: (1) ext_flash Class: altera_avalon_cfi_flash Size: 16777216 bytes Selection: 1 --- Please select a device to execute kernel from: (1) data_RAM Class: altera_avalon_onchip_memory2 Size: 1024 bytes (2) payload_buffer Class: altera_avalon_onchip_memory2 Size: 16384 bytes (3) firmware_ROM Class: altera_avalon_onchip_memory2 Size: 4096 bytes Selection: 1 --- Summary using PTF: altera_nios_dev_board_cyclone_2c35.ptf CPU: cpu_0 Device to upload to: ext_flash Program memory to execute from: data_RAM --- Settings written to /home/Ricky/linux-2.6.x/arch/nios2nommu/hardware.mk [Ricky@localhost linux-2.6.x]$ make ARCH=nios2nommu CROSS_COMPILE=nios2-linux-uclibc- no emulation specific options. CHK include/linux/version.h CHK include/nios2_system.h perl -I/home/Ricky/linux-2.6.x/arch/nios2nommu/scripts /home/Ricky/linux-2.6.x/arch/nios2nommu/scripts/gen_nios2_system.h.pl cpu_0 data_RAM ext_flash < altera_nios_dev_board_cyclone_2c35.ptf > include/nios2_system.h.tmp; if [ -r include/nios2_system.h ] && cmp -s include/nios2_system.h include/nios2_system.h.tmp; then rm -f include/nios2_system.h.tmp; else echo ' UPD include/nios2_system.h'; mv -f include/nios2_system.h.tmp include/nios2_system.h; fi UPD include/nios2_system.h CC arch/nios2nommu/kernel/asm-offsets.s arch/nios2nommu/kernel/asm-offsets.c: In function `main': arch/nios2nommu/kernel/asm-offsets.c:149: error: `na_data_RAM' undeclared (first use in this function) arch/nios2nommu/kernel/asm-offsets.c:149: error: (Each undeclared identifier is reported only once arch/nios2nommu/kernel/asm-offsets.c:149: error: for each function it appears in.) arch/nios2nommu/kernel/asm-offsets.c:150: error: `na_data_RAM_end' undeclared (first use in this function) make[1]: *** [arch/nios2nommu/kernel/asm-offsets.s] Error 1 make: *** [arch/nios2nommu/kernel/asm-offsets.s] Error 2 - Altera_Forum
Sorry, I pointed the wrong path in previous post. (I don't have any dev board)
Find it in page 1-9 in "Nios II Development Kit Getting Started User Guide". http://www.altera.com/literature/ug/ug_nio...ing_started.pdf (http://www.altera.com/literature/ug/ug_nios2_getting_started.pdf) The ptf file should be altera\kits\nios2\examples\verilog\niosII_cycloneII_2c35\standard\std_2C25.ptf And there is a precompiled sof, which you can download to the board. There is no need to edit the asm-offset.c . You should have an option of sdram to "select a device to execute kernel from" during hwselect. - Altera_Forum
Thanks Hippo for the reply. It helped me out too. I had the same problem. Then I realized from reading your post that I had the wrong ptf file. I took the ptf file out of the components... which is WRONG ... as you pointed out we need to get it out of the examples. Which now the kernel and apps compile fine.
THanks.
