20 years agoCompatibility with Quartus 5.1 and Nios 5.1
Hi, I'm a newbie and I'm wondering if the nios1.4 uclinux package can be used on a 2C35 Cyclone II device with Quartus v5.1 and Nios II v5.1 since the pdf hardware/software requirements...
20 years agoSorry, I pointed the wrong path in previous post. (I don't have any dev board)
Find it in page 1-9 in "Nios II Development Kit Getting Started User Guide". http://www.altera.com/literature/ug/ug_nio...ing_started.pdf (http://www.altera.com/literature/ug/ug_nios2_getting_started.pdf) The ptf file should be altera\kits\nios2\examples\verilog\niosII_cycloneII_2c35\standard\std_2C25.ptf And there is a precompiled sof, which you can download to the board. There is no need to edit the asm-offset.c . You should have an option of sdram to "select a device to execute kernel from" during hwselect.
