20 years agoCompatibility with Quartus 5.1 and Nios 5.1
Hi, I'm a newbie and I'm wondering if the nios1.4 uclinux package can be used on a 2C35 Cyclone II device with Quartus v5.1 and Nios II v5.1 since the pdf hardware/software requirements...
20 years agoThe ptf is generated by the sopc builder.
It is used by hwselect perl script to generate the memory map, io ports address and irq number for nios2 uClinux. It must match your hardware. If you use altera dev board, you should find it in your kits, (eg altera/kits/nios2/components/altera_nios_dev_board_cyclone_2c35/system/...). Or if it is a custom board, built it with the minimal components as in the guide.
