20 years ago
CFI and different Command Definition Tables
I am having problems using Quartus Flash Programmer to erase/program CFI flash made by Atmel.
I have a single 64 megabit chip at49bv6416 on my board hooked up to Nios II using Avalon bus and it uses 16-bit data bus.
I know it has a different Command Definition Table than a similar 64 megabit, also CFI compatible chip made by AMD (am29lv640mh).
For example, "Program Word" command for Atmel chip is following sequence:
555/aa
aaa/55
555/a0
for AMD chip the sequence is:
555/aa
2aa/55
555/a0
how the quartus flash programmer "knows" what sequence to use for my chip ?
Command values does not seem to be coded in CFI table...
Do I configure it in some quartus/project file to match my flash chip?
    Yes, I have looked in this file and I learned something new: I can use Flash Programmer in command-line mode to display some more debug messages.
    Here is my output from the program for my board:
    Using cable "USB-Blaster ", device 1, instance 0x01
    Resetting and pausing target processor: OK
    Reading System ID at address 0x00900BC8: verified
    Found CFI table in 16 bit mode
    Raw CFI query table read from device:
       0: 1F 00 D6 00 FF FF FF FF  FF FF FF FF FF FF FF FF  ................
      10: FF FF FF FF FF FF FF FF  FF FF FF FF FF FF FF FF  ................
      20: 51 00 52 00 59 00 02 00  00 00 41 00 00 00 00 00  Q.R.Y.....A.....
      30: 00 00 00 00 00 00 27 00  36 00 09 00 0A 00 04 00  ......'.6.......
      40: 00 00 09 00 10 00 04 00  00 00 03 00 03 00 17 00  ................
      10: 51 52 59 02 00 41 00 00  00 00 00 27 36 09 0A 04  QRY..A.....'6...
      20: 00 09 10 04 00 03 03 17  01 00 00 00 02 7E 00 00  .............~..
      30: 01 07 00 20 00 FF FF FF  FF FF FF FF FF FF FF FF  ... ............
      40: FF                                                .
    CFI extended table read from device:
       0: 50 52 49 31 30 AF 01 00  01 80 03 03 FF FF FF FF  PRI10...........
    Read autoselect code 001F-00D6 (in 16 bit mode)
    No CFI override data for
    Device size is 8MByte
    Erase regions are:
      offset        0: 127 x 64K
      offset   7F0000:   8 x 8K
    Device supports AMD style programming algorithm
    Multi-byte programming not supported
    Sector erase timeout is 4s
    Word program timeout is 256us
                  : Checksumming existing contents
    00200000      : Checksum failed - needs erase then program
    00210000      : Checksum failed - needs erase then program
    00220000      : Checksum failed - needs erase then program
    00230000      : Checksum failed - needs erase then program
    00200000      : Reading existing contents
    00210000      : Reading existing contents
    00220000      : Reading existing contents
    00230000      : Reading existing contents
    Checksummed/read 14kB in 0.4s
    00200000 ( 0%): Erasing
    00210000 (25%): Erasing
    00220000 (50%): Erasing
    00230000 (75%): Erasing
    Erased 256kB in 0.0s
    00200000 ( 0%): Programming
    Program sequence:
      Write address 0x00000000 <= 0xF0
      Write address 0x0000AAAA <= 0xAA
      Write address 0x00005554 <= 0x55
      Write address 0x0000AAAA <= 0xA0
      Write address 0x00200010 <= 0xD76A
      Read  address 0x00200010 => 0xE4
    Program failed at offset 200010
    Leaving target processor paused
    Doing this, I can see the wrong program sequence is used, but I am not sure how to change it to the correctl one. Yes, I can override CFI table using --override=<filename> parameters, but how do I find numbers for CFI table to override?
    Any ideas ?
    Get out your datasheet and compare the read CFI table values with what should be there. Use the override table to "replace" these bad values for (in your case) FLASH-001F-00D6.
    You might be able to find some examples of doing this, on this forum, or, if not, definitely on Altera&#39;s website.
    Best of luck and good job using the --debug option. I&#39;m sorry I didn&#39;t recommend it to you, in the first place.
    Cheers,
    - slacker
