20 years agoCFI and different Command Definition Tables
I am having problems using Quartus Flash Programmer to erase/program CFI flash made by Atmel. I have a single 64 megabit chip at49bv6416 on my board hooked up to Nios II using Avalon bus and it...
20 years agoYes, I have looked in this file and I learned something new: I can use Flash Programmer in command-line mode to display some more debug messages.
Here is my output from the program for my board:Using cable "USB-Blaster ", device 1, instance 0x01
Resetting and pausing target processor: OK
Reading System ID at address 0x00900BC8: verified
Found CFI table in 16 bit mode
Raw CFI query table read from device:
0: 1F 00 D6 00 FF FF FF FF FF FF FF FF FF FF FF FF ................
10: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................
20: 51 00 52 00 59 00 02 00 00 00 41 00 00 00 00 00 Q.R.Y.....A.....
30: 00 00 00 00 00 00 27 00 36 00 09 00 0A 00 04 00 ......'.6.......
40: 00 00 09 00 10 00 04 00 00 00 03 00 03 00 17 00 ................
10: 51 52 59 02 00 41 00 00 00 00 00 27 36 09 0A 04 QRY..A.....'6...
20: 00 09 10 04 00 03 03 17 01 00 00 00 02 7E 00 00 .............~..
30: 01 07 00 20 00 FF FF FF FF FF FF FF FF FF FF FF ... ............
40: FF .
CFI extended table read from device:
0: 50 52 49 31 30 AF 01 00 01 80 03 03 FF FF FF FF PRI10...........
Read autoselect code 001F-00D6 (in 16 bit mode)
No CFI override data for
Device size is 8MByte
Erase regions are:
offset 0: 127 x 64K
offset 7F0000: 8 x 8K
Device supports AMD style programming algorithm
Multi-byte programming not supported
Sector erase timeout is 4s
Word program timeout is 256us
: Checksumming existing contents
00200000 : Checksum failed - needs erase then program
00210000 : Checksum failed - needs erase then program
00220000 : Checksum failed - needs erase then program
00230000 : Checksum failed - needs erase then program
00200000 : Reading existing contents
00210000 : Reading existing contents
00220000 : Reading existing contents
00230000 : Reading existing contents
Checksummed/read 14kB in 0.4s
00200000 ( 0%): Erasing
00210000 (25%): Erasing
00220000 (50%): Erasing
00230000 (75%): Erasing
Erased 256kB in 0.0s
00200000 ( 0%): Programming
Program sequence:
Write address 0x00000000 <= 0xF0
Write address 0x0000AAAA <= 0xAA
Write address 0x00005554 <= 0x55
Write address 0x0000AAAA <= 0xA0
Write address 0x00200010 <= 0xD76A
Read address 0x00200010 => 0xE4
Program failed at offset 200010
Leaving target processor paused Doing this, I can see the wrong program sequence is used, but I am not sure how to change it to the correctl one. Yes, I can override CFI table using --override=<filename> parameters, but how do I find numbers for CFI table to override? Any ideas ?
