20 years agoCFI and different Command Definition Tables
I am having problems using Quartus Flash Programmer to erase/program CFI flash made by Atmel. I have a single 64 megabit chip at49bv6416 on my board hooked up to Nios II using Avalon bus and it...
20 years agoHave you looked at the flash programmer user's guide (http://www.altera.com/literature/ug/ug_nios2_flash_programmer.pdf).
You may be able to define an override to get your CFI "compliant" flash to function. - slacker
