20 years agocan't connect:no route to host.
Hi,now I am meeting a problem.
I ported the uClinux to the DE2 board.I used two DE2 boards to communicate with each other.One board is used as a server with its ip 192.168.135.6,the other is used as a client with its ip 192.168.135.10.My pc's ip is 192.168.135.9. I can ping my pc with either DE2 board, and I can also ping each board with my pc.But I can't ping the DE2 board with the other. so what is the problem? I wrote a server.c and client.c .when I run server.c in the DE2 as the server, I run the client.c in the DE2 as the client,and it displays"can't connect:no route to host." I don't know why.I hope someone can help me . below is the server.c and the client.c .they are simple. /////server.c# include <sys/types.h># include <sys/socket.h># include <sys/ioctl.h># include <sys/time.h># include <netinet/in.h># include <arpa/inet.h># include <netdb.h># include <stdio.h># include <signal.h># include <unistd.h> # define FD_SETSIZE 1024 int main () { int cd,sd; struct sockaddr_in sin,cin; char buf[1024]; int i,n; fd_set rdfds,tsfds; int res,fd,nread; if((sd=socket(AF_INET,SOCK_STREAM,0))==-1) { perror("can't creat socket!"); exit(1); } sin.sin_family=AF_INET; sin.sin_addr.s_addr=htonl(INADDR_ANY); sin.sin_port=htons(1989); if(bind(sd,(struct sockaddr*)&sin,sizeof(sin))==-1) { perror("bind error!"); exit(1); } if(listen(sd,20)==-1) { perror("listen error!"); exit(1); } FD_ZERO(&rdfds); FD_SET(sd,&rdfds); printf("waiting for connections from clients!\n"); while(1) { tsfds=rdfds; res=select(FD_SETSIZE,&tsfds,0,0,0); if(res<1) { perror("can't select!"); exit(1); } for(fd=0;fd<FD_SETSIZE;fd++) { if(FD_ISSET(fd,&tsfds)) { if(fd==sd) //if it is listen descriptor; { if((cd=accept(sd,(struct sockaddr*)&cin,sizeof(cin)))==-1) { perror("accept error!"); exit(1); } FD_SET(cd,&rdfds); printf("add client on fd%d",cd); } else { ioctl(fd,FIONREAD,&nread); if(nread==0) //if client left { close(fd); FD_CLR(fd,&rdfds); printf("remove client on %d",fd); } else //data transfer { if((n=recv(cd,buf,sizeof(buf),0))<0) { perror("receive error!"); exit(1); } printf("received from the client:%s\n",buf); for(i=0;i<=n;i++) buf=toupper(buf); if((n=send(cd,buf,sizeof(buf),0))<0) { perror("send error!"); exit(1); } } } } } } } ///////////////////////client.c# include <sys/types.h># include <sys/socket.h># include <sys/ioctl.h># include <sys/time.h># include <netinet/in.h># include <arpa/inet.h># include <netdb.h># include <stdio.h># include <signal.h># include <unistd.h> int main() { int sd; struct sockaddr_in cin; char buf[1024]; int n; if((sd=socket(AF_INET,SOCK_STREAM,0))==-1) { perror("can't creat socket!"); exit(1); } cin.sin_family=AF_INET; cin.sin_addr.s_addr=inet_addr("192.168.135.6"); cin.sin_port=htons(1989); if(connect(sd,(void*)&cin,sizeof(cin))==-1) { perror("can't connect!"); exit(1); } printf("input a message:\n"); fgets(buf,sizeof(buf),stdin); if((n=send(sd,buf,sizeof(buf),0))==-1) { perror("can't send message!"); exit(1); } if((n=recv(sd,buf,sizeof(buf),0))==-1) { perror("receive error!"); exit(1); } printf("response from server:%s",buf); close(sd); }3 Replies
please check the ethernet hardware address, they can not use the same number.
check with ifconfig, and try to change it with ifconfig eth0 hw ether 11:22:33:44:55:66 replace the number with yours. in case the ifconfig can not work, check the source of your ether driver to setup hw addr. - Altera_Forum
the ifconfig hw ether is not supported.
please check kernel source arch/nios2nommu/kernel/setup.c after line 208. where it gets the hw addr. - Altera_Forum
--- Quote Start --- originally posted by hippo@Sep 24 2006, 11:58 PM the ifconfig hw ether is not supported.please check kernel source arch/nios2nommu/kernel/setup.c after line 208.
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=18433)
--- quote end ---
--- Quote End --- Yes,I checked the hw and both are the same,so the can't ping each other. I modified the source code according to you,and now I solved the problem. I have been busy for the days ,so I can only say thank you by now. thank you very much ,hippo!
