20 years agocan't connect:no route to host.
Hi,now I am meeting a problem. I ported the uClinux to the DE2 board.I used two DE2 boards to communicate with each other.One board is used as a server with its ip 192.168.135.6,the other is used ...
20 years ago --- Quote Start --- originally posted by hippo@Sep 24 2006, 11:58 PM the ifconfig hw ether is not supported.
please check kernel source arch/nios2nommu/kernel/setup.c after line 208.
where it gets the hw addr.
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=18433)
--- quote end ---
--- Quote End --- Yes,I checked the hw and both are the same,so the can't ping each other. I modified the source code according to you,and now I solved the problem. I have been busy for the days ,so I can only say thank you by now. thank you very much ,hippo!
