Can PCI Wifi Cards works under uClinux in 1s10?
Hi, hippo, http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/blink.gif
I want to connect the pci wireless network adapter with my stratix board. And I wonder that can altera pci complier help me in this situation when using it in Host-Bridge mode. Thank you in advance!8 Replies
The PCI driver is quite portable. People on this forum had used it for gigabit ethernet, IEEE1394, and USB. It is not difficult to add a wifi. You'd find a wifi card with kernel driver support, not ndiswrapper. You may find the PCI host usage in the wiki.
But you should know the Altera dev board does not have PCI or mini-PCI slot. How do you connect it? - Altera_Forum
Thanks! I read some posts before about using pci driver to connect ethernet device and other device, but I am not quite sure about wifi. >>But you should know the Altera dev board does not have PCI or mini-PCI slot. How do you connect it? Yes, the Altera dev board does not have PCI slot. I want to make a daughter card in which there is a PCI slot, and use the Expansion Prototype Connector in altera board to connect the daughter card. Does this work? >>You may find the PCI host usage in the wiki. btw, I am in mainland and I can not log on the nioswiki now. - Altera_Forum
Hippo, can you give me some other advice or methods about connecting the altera dev board with PCI wifi card? I've tried using CF interface in this altera board, but I found that the cf in altera only support the ture IDE mode, and it does not support IO mode.
Since you know the board very well, what do you think if you want to connect wifi card using the altera board. - Altera_Forum
About the wiki, I had asked Altera's FAE to check the wiki from mainland China before. They told me it worked. I wonder if it was interrupted by the earth quack earlier.
About the wifi, 1. It is difficult to add PCI slot to Altera dev board. It will be not so stable, too. 2. There are few Wifi CF adaptors. You must check if they have Linux driver. The CF slot on Altera dev board can be used. 3. USB wifi cards are popular. I had tested with USB host on PCI. But Altera dev board does not have USB host. DE2 has one, but the driver has problem. 4. You can also use ethernet to connect a standalone wifi AP, and make it at client or bridge mode. This is the simple way. - Altera_Forum
You mean that I can use the altera's CF slot to connect cf Wifi card, but when I do this in SOPC Builder, just getting the CF interface supports only True IDE mode, and Wifi card needs IO mode. So I think I need to write CF Controller module, which complies with Avalon bus specification, to handle the Compact Flash singals with Wifi card, and just use the CF slot, not the CF interface function provided by SoPC Builder. Really appreciate your help! - Altera_Forum
Yes, you need to change the CF itnerface to IO mode.
But it is difficult to find a CF adaptor with native Linux dirver. I couldn't find one myself. - Altera_Forum
--- Quote Start --- originally posted by hippo@Jan 19 2007, 09:20 AM yes, you need to change the cf itnerface to io mode.but it is difficult to find a cf adaptor with native linux dirver. i couldn't find one myself.
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=20701)
--- quote end ---
--- Quote End --- Got this, http://72.14.235.104/search?q=cache:mkybij...lient=firefox-a (http://72.14.235.104/search?q=cache:mkybij6fmesj:docs.blackfin.uclinux.org/doku.php%3fid%3dblackfin_802.11_wlan_-_orinoco_based_driver+d-link+dcf-660w+blackfin+uclinux&hl=zh-tw&gl=tw&ct=clnk&cd=1&client=firefox-a) http://www.expansys.cn/p.aspx?i=104537 (http://www.expansys.cn/p.aspx?i=104537) http://pcmcia-cs.sourceforge.net/ftp/supported.cards (http://pcmcia-cs.sourceforge.net/ftp/supported.cards) Wireless network adapters: [airo_cs driver] [x86] Aironet PC4500, PC4800 Cisco 340, 350 Xircom Wireless Ethernet Adapter [netwave_cs driver] [x86] Breezenet SA-PX Xircom CreditCard Netwave [ray_cs driver] [x86,axp] BUSlink Wireless LAN Adapter Raytheon Raylink WebGear Aviator 2.4, Aviator Pro [wavelan_cs driver] [x86,smp] AT&T / NCR / Lucent WaveLAN version 2.0 DEC RoamAbout/DS [orinoco_cs driver] [x86,axp,ppc,smp] [ this driver supports multiple chipsets and some features may not be supported for all cards ] 3Com AirConnect 1stWave 1ST-PC-DSS11IS, DSS11IG, DSS11ES, DSS11EG Actiontec HWC01170-01/802C12 Adaptec ANW-8030 Addtron AWP-100 Airvast WN-100 Ambicom WL1100 PC ARtem Onair ComCard STD & EMB versions, 128- & 64-bit ASUS SpaceLink WL-100 Avaya World Card Belkin F5D6020 [only Version 1] Buffalo WLI-PCM-S11 Cabletron/Enterasys RoamAbout 802.11 DS Compaq WL100, HNW-100 Conceptronic CON11Cpro Corega PCCA-11, PCC-11 Dell TrueMobile 1150 Series D-Link DRC-650, DCF-650W, DWL-660, DCF-660W D-Link DWL-650 [older version, NOT new CardBus ones or 650+] EagleTec ET-WL300NE-CC Efficient SpeedStream SS1021 [old 16-bit, NOT new CardBus ones] ELSA AirLancer MC-11 Ericsson WLAN Card C11 Farallon SkyLINE HP F2136B HyperLink Wireless IBM High Rate Wireless LAN Intel PRO/Wireless 2011 LA4111 Spectrum24 Wireless LAN Linksys WPC11 Instant Wireless [ NOT the CardBus v4 card ] Linksys WCF12 Wireless CompactFlash Lucent Orinoco WaveLAN/IEEE 802.11(http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/cool.gif Melco WLI-PCM-L11, WLI-PCM-L11G Microsoft MN-520 NCR WaveLAN/IEEE 802.11 Netgear MA401RA Nortel Networks eMobility Planet WL-3550 PLANEX GeoWave GW-CF110, RoadLannerWave GW-NS11H Proxim Harmony 802.11b Safeway Wireless Samsung 11Mbps WLAN Sandisk Connect SDWCFB-000 Seg Communications XI325H SMC2632W, SMC2532W-B Sohoware NCP110 Netblaster II Tekram AIR.mate PCF 200 ZCOMAX AirRunner/XI=300
Thanks a lot!
So many cards! I need some times to find! Maybe I have another choice, Prism2/2.5/3 card. It can work well in linux, I think. And in linux-wlan there has driver. God bless me finding the card!
