19 years agoCan PCI Wifi Cards works under uClinux in 1s10?
Hi, hippo, http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/blink.gif I want to connect the pci wireless network adapter with my stratix board. And I wonder that can altera pci comp...
19 years ago>>2. There are few Wifi CF adaptors. You must check if they have Linux driver. The CF slot on Altera dev board can be used.
You mean that I can use the altera's CF slot to connect cf Wifi card, but when I do this in SOPC Builder, just getting the CF interface supports only True IDE mode, and Wifi card needs IO mode. So I think I need to write CF Controller module, which complies with Avalon bus specification, to handle the Compact Flash singals with Wifi card, and just use the CF slot, not the CF interface function provided by SoPC Builder. Really appreciate your help!
