19 years agoCan PCI Wifi Cards works under uClinux in 1s10?
Hi, hippo, http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/blink.gif I want to connect the pci wireless network adapter with my stratix board. And I wonder that can altera pci comp...
19 years agoAbout the wiki, I had asked Altera's FAE to check the wiki from mainland China before. They told me it worked. I wonder if it was interrupted by the earth quack earlier.
About the wifi, 1. It is difficult to add PCI slot to Altera dev board. It will be not so stable, too. 2. There are few Wifi CF adaptors. You must check if they have Linux driver. The CF slot on Altera dev board can be used. 3. USB wifi cards are popular. I had tested with USB host on PCI. But Altera dev board does not have USB host. DE2 has one, but the driver has problem. 4. You can also use ethernet to connect a standalone wifi AP, and make it at client or bridge mode. This is the simple way.
