Can I upload Nios2 SMP system?
Hi, guys & Altera corp.
I'm now making a Nios2 SMP system for my research purpose. It's still a little bit buggy and slow, but I succeeded to boot Linux kernel and execute bash.
Linux version 2.6.30 (hamada@Messiah2) (gcc version 4.1.2 (Wind River Linux Sour
cery G++ 4.1-176))# 1915 SMP Tue Sep 4 18:16:32 JST 2012
console enabled
Early printk initialized
Linux/Nios II-MMU
Altera Nios II-MMU support (C) 2004 Wind River Systems.
init_bootmem_node(?,0x3d0, 0x0, 0x8000)
free_bootmem(0x3d0000, 0x7c30000)
reserve_bootmem(0x3d0000, 0x1000)
Detected 1 available secondary CPU(s)
Built 1 zonelists in Zone order, mobility grouping on. Total pages: 32512
Kernel command line: kgdboc=ttyS0, 115200 kgdbwait
NR_IRQS:32
PID hash table entries: 512 (order: 9, 2048 bytes)
Console: colour dummy device 80x25
Dentry cache hash table entries: 16384 (order: 4, 65536 bytes)
Inode-cache hash table entries: 8192 (order: 3, 32768 bytes)
We have 32768 pages of RAM
Memory available: 125824k/3902k RAM, 0k/0k ROM (1457k kernel code, 2445k data)
Calibrating delay loop... 19.55 BogoMIPS (lpj=97792)
Mount-cache hash table entries: 512
CPU1: Booted secondary processor
Calibrating delay loop... 19.96 BogoMIPS (lpj=99840)
Brought up 2 CPUs
SMP: Total of 2 processors activated (39.52 BogoMIPS).
init_BSP(): registering device resources
bio: create slab <bio-0> at 0
msgmni has been set to 246
io scheduler noop registered
io scheduler anticipatory registered
io scheduler deadline registered
io scheduler cfq registered (default)
ttyJ0 at MMIO 0xa60a440 (irq = 2) is a Altera JTAG UART
console handover: boot -> real
ttyS0 at MMIO 0x8000060 (irq = 3) is a Altera UART
ifconfig: socket: Function not implemented
Welcome to
____ _ _
/ __| ||_|
_ _| | | | _ ____ _ _ _ _
| | | | | | || | _ \| | | |\ \/ /
| |_| | |__| || | | | | |_| |/ \
| ___\____|_||_|_| |_|\____|\_/\_/
|_|
For further information check:
http://www.uclinux.org/
Why came here? CPU0, task inetd pte c71f4c40, entry 07a0704b, address 2ab10000
BusyBox v1.14.2 (2012-06-26 16:39:29 JST) hush - the humble shell
Enter 'help' for a list of built-in commands.
/# ls
bin etc init mnt root sys usr
dev home lib proc sbin tmp var
/# bash # ls -lp
drwxr-xr-x 2 root root 0 Sep 4 2012 bin/
drwxr-xr-x 6 root root 0 Sep 4 2012 dev/
drwxr-xr-x 5 root root 0 Sep 4 2012 etc/
drwxr-xr-x 3 root root 0 Sep 4 2012 home/
lrwxrwxrwx 1 root root 10 Sep 4 2012 init -> /sbin/init
drwxr-xr-x 3 root root 0 Sep 4 2012 lib/
drwxr-xr-x 2 root root 0 Sep 4 2012 mnt/
dr-xr-xr-x 34 root root 0 Nov 30 00:00 proc/
drwxr-xr-x 2 root root 0 Sep 4 2012 root/
lrwxrwxrwx 1 root root 3 Sep 4 2012 sbin -> bin/
drwxr-xr-x 11 root root 0 Nov 30 00:00 sys/
drwxr-xr-x 2 root root 0 Nov 30 00:01 tmp/
drwxr-xr-x 5 root root 0 Sep 4 2012 usr/
drwxr-xr-x 7 root root 0 Nov 30 00:01 var/ # cat /proc/cpuinfo
CPU: NIOS2 MultiCore
MMU: ways:16 entries:512
FPU: none
Clocking: <not supported>
BogoMips: 19.96
Calibration: 9984000 loops
FPU: none
BogoMips: 19.96
Calibration: 9984000 loops # cat /proc/interrupts
CPU0
0: 13931 NIOS2-INTC timer
2: 133 NIOS2-INTC JTAGUART
3: 0 NIOS2-INTC UART
30: 4875 NIOS2-INTC IPI 0
31: 17375 NIOS2-INTC IPI 1 # cat /proc/stat
cpu 124 0 27259 1939 0 0 2 0 0
cpu0 54 0 13448 1183 0 0 2 0 0
cpu1 70 0 13811 756 0 0 0 0 0
intr 38284 14687 0 163 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 515
9 18275
ctxt 33554
btime 943920000
processes 674
procs_running 2
procs_blocked 0 #
The cpu core is a clone of the genuine Nios2/f core and almost all features are implemented except the details of 1st data cache. If anyone has interest, I want to upload these to 'Altera Wiki', but it's a problem because the 'cpu' is a clone and Altera corp. has their copyright for Nios2's instruction set and its architecture. If Altera corp. kindly permit me to upload all including hardware's source codes, this is the best way. But if not so, how can we share these result? Kazu15 Replies
How are you getting around the problem that the nios has no locked bus cycles - so you can't implement any mutex or other atomic operations into normal memory?
Typically these need a minimum of a locked 'compare and exchange' instruction - which the avalon bus doesn't support. If you've re-implemented nios, you might notice that nios is basically a reimplementation of MIPS :-) - Altera_Forum
Its not possible to do an SMP Linux system on Altera NIOS (see several discussions on this). Altera would need to implement SMP-save atomic instructions first. (See e.g. ARM's "load locked", "store conditional" instructions for a decent way to do this.)
I understand that you created a NIOS compatible CPU yourself. Of course here you can in fact implement such instructions, but I feel that a NIOS clone (done in Verilog or whatever) will be much slower than an Altera branded thingy that uses low-level optimizations that Verilog and friends don't provide. I agree that implementing a MIPS clone seems more appropriate than implementing a NIOS clone There are some free 32 Bit CPUs in Verilog code available in the Net. Of course cache synchronization is a huge task to do. -Michael - Altera_Forum
--- Quote Start --- How are you getting around the problem that the nios has no locked bus cycles - so you can't implement any mutex or other atomic operations into normal memory? Typically these need a minimum of a locked 'compare and exchange' instruction - which the avalon bus doesn't support. --- Quote End --- I implemented an instruction which swaps the values between the register and memory operand in atomic, like
. Spinlocks are using this. And the 'compare and exchange' instruction is implemented with the combination of spinlocks likeswap ra, imm16
in the Linux kernel. --- Quote Start --- If you've re-implemented nios, you might notice that nios is basically a reimplementation of MIPS :-) --- Quote End --- Of course, I know that Nios2 is a copy of ....:D --- Quote Start --- I understand that you created a NIOS compatible CPU yourself. Of course here you can in fact implement such instructions, but I feel that a NIOS clone (done in Verilog or whatever) will be much slower than an Altera branded thingy that uses low-level optimizations that Verilog and friends don't provide. --- Quote End --- Of course, clone core's fmax is a big problem if you want to achieve better performance than single core case. I compiled the source for my DE2-115 with switches 'less Optimizations' and 'Fast fit', and got the fmax result around 60MHz. By optimizing the details and compilation switches, may be I can get 75~80MHz, but over 100MHz is impossible. --- Quote Start --- I agree that implementing a MIPS clone seems more appropriate than implementing a NIOS clone There are some free 32 Bit CPUs in Verilog code available in the Net. --- Quote End --- Why Nios2? Because I love Nios2:) and Altera:D. --- Quote Start --- Of course cache synchronization is a huge task to do. --- Quote End --- To achieve the cache coherency, I implemented the 1st data cache as 'write through' one, and set the cache flush signals which are sent to other cpu's data cache whenever the write operations are done. If the target data has been cached in other caches, it's only flushed from the cache. The new data is filled at the next memory access. Kazustatic inline int atomic_cmpxchg(atomic_t *v, int old, int new) { int ret; unsigned long flags; _atomic_spin_lock_irqsave(v, flags); ret = v->counter; if (likely(ret == old)) v->counter = new; _atomic_spin_unlock_irqrestore(v, flags); return ret; } - Altera_Forum
Sounds nice.
It would be great if a way could be found (maybe with Altera's help) to use the original NIOS implementation and add what's necassary. -Michael - Altera_Forum
As we discussed it before, to make a clone cpu which has atomic instructions is 'one solution' to build the Nios2 SMP system. --- Quote Start --- It would be great if a way could be found (maybe with Altera's help) to use the original NIOS implementation and add what's necassary. --- Quote End --- By this research, I understand how to make a SMP system from the view points of hardware and software sides, so I'm now seeking the way to make it by using original Nios2 processors. Kazu - Altera_Forum
If you can do the locked read-write avalon bus cycle you should be able to generate one from a custom instruction - except it would have to use a separate avalon master and so bypass the data cache.
Actually you'll have no cache coherencey either - very grim! You'd have to use an external data cache. I've thought that the nios cpu isn't much more than a great heap of mux. My guess is that RA and RB are always read, pipeline stalls (re-execute) if a write to RA is pending, and for RB if the low two instruction bits differ (NFI why the instructions aren't organised so this is a single bit!). This gives the instrcution three 32bit words to play with, write-back to RB or RC is dependant on the decoded instruction. That makes me think that the readra/readrb bits of the custom instruction are ignored - but I've not done any experiments. - Altera_Forum
--- Quote Start --- If you can do the locked read-write avalon bus cycle you should be able to generate one from a custom instruction - except it would have to use a separate avalon master and so bypass the data cache. Actually you'll have no cache coherencey either - very grim! You'd have to use an external data cache. --- Quote End --- Of course, we must add some custom instructions to do locked read-write memory operations, but we can't forget the existence of MMU. About the cache coherency, we can remove the original data cache and put special one. --- Quote Start --- I've thought that the nios cpu isn't much more than a great heap of mux. My guess is that RA and RB are always read, pipeline stalls (re-execute) if a write to RA is pending, and for RB if the low two instruction bits differ (NFI why the instructions aren't organised so this is a single bit!). This gives the instrcution three 32bit words to play with, write-back to RB or RC is dependant on the decoded instruction. That makes me think that the readra/readrb bits of the custom instruction are ignored - but I've not done any experiments. --- Quote End --- I think that the readra/readrb bits are used in the forwarding and pipe-lock mechanism. Kazu - Altera_Forum
My point about readra/readrb is that the logic that handles the pipeline stall doesn't really want to look that far into the instruction decode.
--- Quote Start --- My point about readra/readrb is that the logic that handles the pipeline stall doesn't really want to look that far into the instruction decode. --- Quote End --- Maybe, Altera uses embedded memories for the Nios's register files, and sets those in the same clock phase of the 'Decode Stage'. To read the contents of the embedded memories, it takes one clock, so the RA & RB field data must be sent directly from the 'Fetch Stage' to the register file. The contents of the register file are always discharged to the following stage even when those are not used. But to avoid the 'RAW' hazard, the 'Decode Stage' must decide whether the RA and RB are really used or not. I don't know whether Altera uses readra and readrb bits for this purpose or not, because the 'R0' register can be used instead of those. Kazu - Altera_Forum
I succeeded to make a Nios2 SMP system by using normal Nios2/f cores. It's still a little bit buggy, but I'm going to upload the sources and documents on Altera wiki in near future.
KazuLinux version 2.6.30-00471-g2e1b9d6-dirty (hamada@Messiah2) (gcc version 4.1.2 ( Wind River Linux Sourcery G++ 4.1-176))# 2077 SMP PREEMPT Sun Oct 21 16:34:00 JS T 2012 console enabled Early printk initialized Linux/Nios II-MMU Altera Nios II-MMU support (C) 2004 Wind River Systems. init_bootmem_node(?,0x3d9, 0x0, 0x8000) free_bootmem(0x3d9000, 0x7c27000) reserve_bootmem(0x3d9000, 0x1000) Detected 1 available secondary CPU(s) Built 1 zonelists in Zone order, mobility grouping on. Total pages: 32512 Kernel command line: kgdboc=ttyS0, 115200 kgdbwait NR_IRQS:32 PID hash table entries: 512 (order: 9, 2048 bytes) Console: colour dummy device 80x25 Dentry cache hash table entries: 16384 (order: 4, 65536 bytes) Inode-cache hash table entsucceedries: 8192 (order: 3, 32768 bytes) We have 32768 pages of RAM Memory available: 125808k/3938k RAM, 0k/0k ROM (1485k kernel code, 2452k data) Calibrating delay loop... 24.21 BogoMIPS (lpj=121088) Mount-cache hash table entries: 512 CPU1: Booted secondary processor Calibrating delay loop... 24.98 BogoMIPS (lpj=124928) Brought up 2 CPUs SMP: Total of 2 processors activated (49.20 BogoMIPS). init_BSP(): registering device resources bio: create slab <bio-0> at 0 msgmni has been set to 246 io scheduler noop registered io scheduler anticipatory registered io scheduler deadline registered io scheduler cfq registered (default) ttyJ0 at MMIO 0xa60a500 (irq = 2) is a Altera JTAG UART console handover: boot -> real ttyS0 at MMIO 0x8000060 (irq = 3) is a Altera UART init.rc Welcome to ____ _ _ / __| ||_| _ _| | | | _ ____ _ _ _ _ | | | | | | || | _ \| | | |\ \/ / | |_| | |__| || | | | | |_| |/ | ___\____|_||_|_| |_|\____|\_/\_/ | | |_| For further information check: http://www.uclinux.org/ BusyBox v1.14.2 (2012-09-17 02:11:26 JST) hush - the humble shell Enter 'help' for a list of built-in commands. /# bash# cat /proc/cpuinfo CPU: NIOS2 MultiCore MMU: ways:16 entries:512 FPU: none Clocking: <not supported> BogoMips: 24.98 Calibration: 12492800 loops CPU: NIOS2 MultiCore MMU: ways:16 entries:512 FPU: none Clocking: <not supported> BogoMips: 24.98 Calibration: 12492800 loops# cat /proc/interrupts CPU0 0: 25375 NIOS2-INTC timer 2: 130 NIOS2-INTC JTAGUART 3: 0 NIOS2-INTC UART 30: 1993 NIOS2-INTC IPI 0 31: 30282 NIOS2-INTC IPI 1# cat /proc/stat cpu 102 0 41939 10290 0 0 1 0 0 cpu0 67 0 19033 7103 0 0 0 0 0 cpu1 35 0 22906 3187 0 0 1 0 0 intr 59916 26203 0 166 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 220 5 31342 ctxt 15553 btime 943920000 processes 670 procs_running 2 procs_blocked 0#
