14 years agoCan I upload Nios2 SMP system?
Hi, guys & Altera corp. I'm now making a Nios2 SMP system for my research purpose. It's still a little bit buggy and slow, but I succeeded to boot Linux kernel and execute bash.
Linux ...
14 years agoHow are you getting around the problem that the nios has no locked bus cycles - so you can't implement any mutex or other atomic operations into normal memory?
Typically these need a minimum of a locked 'compare and exchange' instruction - which the avalon bus doesn't support. If you've re-implemented nios, you might notice that nios is basically a reimplementation of MIPS :-)
