20 years agobuildroot snapshot update 20060426
The buildroot snapshots will last for only one month.
The 20060320 as specified in build script no longer exist. So we have to move to a newer snapshot. Note if you have the toolchain working, there is no need to update. edit build script, change line29 to "SNAPSHOT=20060426" break from line44 of build script, just before make . in ~/buildroot, do make menuconfig, disable c++ in toolchain option. Then make, it will fail in busybox strip, edit ~/buildroot/build_nios2/busybox/Makefile, comment out line306, do_strip. make again. restart from line45 of build script.7 Replies
--- Quote Start --- originally posted by hippo@Apr 27 2006, 04:43 AM the buildroot snapshots will last for only one month.the 20060320 as specified in build script no longer exist.
so we have to move to a newer snapshot.
note if you have the toolchain working, there is no need to update.
edit build script, change line29 to "snapshot=20060426"
then make, it will fail in busybox strip,
edit ~/buildroot/build_nios2/busybox/makefile, comment out line306, do_strip.
make again.
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=14734)
--- quote end ---
--- Quote End --- Hi hippo, I'm retrying with the updated version of your buildroot. Following your instruction, I cut from line 44 (including make) and pasted in a new file. I executed the build script, ok. In ~/buildroot/ I entered make menuconfig and this is what I've got
I'm under FC5 and I installed and linked the gcc32.$ make menuconfig make -C package/config ncurses conf mconf make: Entering directory `/home/MFM/buildroot/package/config' make: `conf' is up to date. gcc -Wall -Wstrict-prototypes -O2 -fomit-frame-pointer -DCURSES_LOC="<curses.h>" -I. -c mconf.c -o mconf.o In file included from mconf.c:26: lxdialog/dialog.h:33:20: curses.h: No such file or directory In file included from mconf.c:26: lxdialog/dialog.h:131: syntax error before "use_colors" lxdialog/dialog.h:131: warning: type defaults to `int' in declaration of `use_colors' lxdialog/dialog.h:131: warning: data definition has no type or storage class lxdialog/dialog.h:133: syntax error before "attributes" lxdialog/dialog.h:133: warning: type defaults to `int' in declaration of `attributes' lxdialog/dialog.h:133: warning: data definition has no type or storage class lxdialog/dialog.h:153: syntax error before '*' token lxdialog/dialog.h:153: warning: function declaration isn't a prototype lxdialog/dialog.h:155: syntax error before '*' token lxdialog/dialog.h:155: warning: function declaration isn't a prototype lxdialog/dialog.h:156: syntax error before '*' token lxdialog/dialog.h:156: warning: function declaration isn't a prototype lxdialog/dialog.h:157: syntax error before '*' token lxdialog/dialog.h:158: warning: function declaration isn't a prototype lxdialog/dialog.h:159: syntax error before '*' token lxdialog/dialog.h:159: warning: function declaration isn't a prototype lxdialog/dialog.h:133: warning: array `attributes' assumed to have one element make: *** Error 1 make: Leaving directory `/home/MFM/buildroot/package/config' make: *** Error 2 $ - Altera_Forum
--- Quote Start --- originally posted by mfm@May 4 2006, 10:41 AM hi hippo,i'm retrying with the updated version of your buildroot.
following your instruction, i cut from line 44 (including make) and pasted in a new file.
i executed the build script, ok.
in ~/buildroot/ i entered make menuconfig and this is what i've got
$ make menuconfig make -c package/config ncurses conf mconf make: entering directory `/home/mfm/buildroot/package/config' make: `conf' is up to date. gcc -wall -wstrict-prototypes -o2 -fomit-frame-pointer -dcurses_loc="<curses.h>" -i. -c mconf.c -o mconf.o in file included from mconf.c:26: lxdialog/dialog.h:33:20: curses.h: no such file or directory $i'm under fc5 and i installed and linked the gcc32.
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=15057)</div> --- Quote End --- Have you installed the ncurses-devel package? - slacker
<div class='quotetop'>QUOTE </div>
--- Quote Start --- Have you installed the ncurses-devel package?[/b] --- Quote End --- Not even heard about, and the buildroot doesn't indicate that we must install it. - Altera_Forum
Right, but I'd bet that a fair number of systems out there have it installed, as part of the "development" installation option.
make menuconfig certainly needs it. - slacker - Altera_Forum
--- Quote Start --- originally posted by mfm@May 4 2006, 05:06 PM <div class='quotetop'>quote--- quote end ---
--- quote start ---
have you installed the ncurses-devel package? --- Quote End --- Not even heard about, and the buildroot doesn't indicate that we must install it. <div align='right'><{post_snapback}> (index.php?act=findpost&pid=15064)</div> [/b] --- Quote End --- It is impossible to list all the packages required right down to the base ones... ncurses is a typical package, as well as ncurses-dev. All the menuconfig stuff uses ncurses, so I wouldn't be surprised if it's required.
sorry guys, I forgot to thank you, so thanks, I installed the ncurses-devel package and things get fixed. - Altera_Forum
TO_BE_DONE
