20 years agobuildroot snapshot update 20060426
The buildroot snapshots will last for only one month. The 20060320 as specified in build script no longer exist. So we have to move to a newer snapshot. Note if you have the toolchain working,...
20 years ago --- Quote Start --- originally posted by hippo@Apr 27 2006, 04:43 AM the buildroot snapshots will last for only one month.
the 20060320 as specified in build script no longer exist.
so we have to move to a newer snapshot.
note if you have the toolchain working, there is no need to update.
edit build script, change line29 to "snapshot=20060426"
break from line44 of build script, just before make .
in ~/buildroot, do make menuconfig, disable c++ in toolchain option.
then make, it will fail in busybox strip,
edit ~/buildroot/build_nios2/busybox/makefile, comment out line306, do_strip.
make again.
restart from line45 of build script.
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=14734)
--- quote end ---
--- Quote End --- Hi hippo, I'm retrying with the updated version of your buildroot. Following your instruction, I cut from line 44 (including make) and pasted in a new file. I executed the build script, ok. In ~/buildroot/ I entered make menuconfig and this is what I've got
$ make menuconfig
make -C package/config ncurses conf mconf
make: Entering directory `/home/MFM/buildroot/package/config'
make: `conf' is up to date.
gcc -Wall -Wstrict-prototypes -O2 -fomit-frame-pointer -DCURSES_LOC="<curses.h>" -I. -c mconf.c -o mconf.o
In file included from mconf.c:26:
lxdialog/dialog.h:33:20: curses.h: No such file or directory
lxdialog/dialog.h:131: syntax error before "use_colors"
lxdialog/dialog.h:131: warning: type defaults to `int' in declaration of `use_colors'
lxdialog/dialog.h:131: warning: data definition has no type or storage class
lxdialog/dialog.h:133: syntax error before "attributes"
lxdialog/dialog.h:133: warning: type defaults to `int' in declaration of `attributes'
lxdialog/dialog.h:133: warning: data definition has no type or storage class
lxdialog/dialog.h:153: syntax error before '*' token
lxdialog/dialog.h:153: warning: function declaration isn't a prototype
lxdialog/dialog.h:155: syntax error before '*' token
lxdialog/dialog.h:155: warning: function declaration isn't a prototype
lxdialog/dialog.h:156: syntax error before '*' token
lxdialog/dialog.h:156: warning: function declaration isn't a prototype
lxdialog/dialog.h:157: syntax error before '*' token
lxdialog/dialog.h:158: warning: function declaration isn't a prototype
lxdialog/dialog.h:159: syntax error before '*' token
lxdialog/dialog.h:159: warning: function declaration isn't a prototype
lxdialog/dialog.h:133: warning: array `attributes' assumed to have one element
make: *** Error 1
make: Leaving directory `/home/MFM/buildroot/package/config'
make: *** Error 2
$ I'm under FC5 and I installed and linked the gcc32.
