20 years agobuildroot snapshot update 20060426
The buildroot snapshots will last for only one month. The 20060320 as specified in build script no longer exist. So we have to move to a newer snapshot. Note if you have the toolchain working,...
20 years ago --- Quote Start --- originally posted by mfm@May 4 2006, 10:41 AM hi hippo,
i'm retrying with the updated version of your buildroot.
following your instruction, i cut from line 44 (including make) and pasted in a new file.
i executed the build script, ok.
in ~/buildroot/ i entered make menuconfig and this is what i've got
$ make menuconfig
make -c package/config ncurses conf mconf
make: entering directory `/home/mfm/buildroot/package/config'
make: `conf' is up to date.
gcc -wall -wstrict-prototypes -o2 -fomit-frame-pointer -dcurses_loc="<curses.h>" -i. -c mconf.c -o mconf.o
in file included from mconf.c:26:
lxdialog/dialog.h:33:20: curses.h: no such file or directory
$ i'm under fc5 and i installed and linked the gcc32.
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=15057)</div> --- Quote End --- Have you installed the ncurses-devel package? - slacker
