11 years ago
boot from S25FL512S
Hi all,
I try to boot from QSPI Flash (S25FL512S) but I am having some difficulties.
I have the same DDR3 as altera cyclone v soc board + two QSPI S25FL512S connected to the hps side. Input clock for FPGA and HPS = 25MHz.
First, I followed the tutorial on rocketboard:
http://rocketboards.org/foswiki/view/documentation/gsrd131qspiboot
but the flash was not detected, then, I added these lines in u-boot spl file spansion.c
        .idcode1 = 0x0220,
        .idcode2 = 0x4d00,
        .pages_per_sector = 256,
        .nr_sectors = 1024,
        .name = "S25FL512S",
but i still have a problem, the board reboot non stop with this log rather than going to u-boot
U-Boot SPL 2013.01.01 (Jun 29 2015 - 17:26:52)
BOARD : Altera SOCFPGA Cyclone V Board
CLOCK: EOSC1 clock 25000 KHz
CLOCK: EOSC2 clock 25000 KHz
CLOCK: F2S_SDR_REF clock 0 KHz
CLOCK: F2S_PER_REF clock 0 KHz
CLOCK: MPU clock 400 MHz
CLOCK: DDR clock 400 MHz
CLOCK: UART clock 100000 KHz
CLOCK: MMC clock 488 KHz
CLOCK: QSPI clock 200000 KHz
RESET: WARM
INFO : Watchdog enabled
SDRAM: Initializing MMR registers
SDRAM: Calibrating PHY
SEQ.C: Preparing to start memory calibration
SEQ.C: CALIBRATION PASSED
SDRAM: 512 MiB
SF: Read data capture delay calibrated to 1 (0 - 2)
SF: Detected S25FL512S
I have no idea, I have tried many things. I can boot with the arrow sockit but the flash is different.
there is something missing :/
I attached my quartus design.
thank you for your help
