11 years agoboot from S25FL512S
Hi all, I try to boot from QSPI Flash (S25FL512S) but I am having some difficulties. I have the same DDR3 as altera cyclone v soc board + two QSPI S25FL512S connected to the hps side. Inp...
11 years agoHi slesne,
thank you for the information I saw this patch only spansion.c change, now I also use this version for the preloader and u-boot + i added some modifications in uboot-socfpga/drivers/mtd/spi/spansion.c 1. Replace flash->sector_size = 256 * params->pages_per_sector; With: flash->sector_size = 512 * params->pages_per_sector; 2. I added { .idcode1 = 0x0220, .idcode2 = 0x4d00, .pages_per_sector = 512, .nr_sectors = 256, .name = "S25FL512S", }, Also change the following in uboot-socfpga/include/configs/socfpga_common.h: From this: # define CONFIG_CQSPI_PAGE_SIZE (256) To this: # define CONFIG_CQSPI_PAGE_SIZE (512) but i still have the same problem so run the preloader code step by step with the debugger i stop at this line (line 191 in spl.c) image_entry((u32 *)boot_params_ptr); I think my changes to support this flash are not good to jump to the next image
