11 years agoboot from S25FL512S
Hi all, I try to boot from QSPI Flash (S25FL512S) but I am having some difficulties. I have the same DDR3 as altera cyclone v soc board + two QSPI S25FL512S connected to the hps side. Inp...
11 years agoHi slesne,
you have right
U-Boot SPL 2013.01.01 (Jul 02 2015 - 16:30:48)
BOARD : Altera SOCFPGA Cyclone V Board
CLOCK: EOSC1 clock 25000 KHz
CLOCK: EOSC2 clock 25000 KHz
CLOCK: F2S_SDR_REF clock 0 KHz
CLOCK: F2S_PER_REF clock 0 KHz
CLOCK: MPU clock 800 MHz
CLOCK: DDR clock 330 MHz
CLOCK: UART clock 100000 KHz
CLOCK: MMC clock 488 KHz
CLOCK: QSPI clock 400000 KHz
RESET: COLD
SDRAM: Initializing MMR registers
SDRAM: Calibrating PHY
SEQ.C: Preparing to start memory calibration
SEQ.C: CALIBRATION PASSED
SDRAM: 512 MiB
SF: Read data capture delay calibrated to 3 (0 - 7)
SF: Detected S25FL512S with page size 262144, total: 67108864
U-Boot 2013.01.01-00114-g9381569-dirty (Jul 02 2015 - 16:30:54)
CPU : Altera SOCFPGA Platform
I2C: ready
DRAM: 256 MiB
MMC: ALTERA DWMMC: 0
*** Warning - bad CRC, using default environment
In: serial
Out: serial
Err: serial
Skipped ethaddr assignment due to invalid EMAC address in EEPROM
Net: mii0
Warning: failed to set MAC address
Hit any key to stop autoboot: 0
** Bad device mmc 0 **
Optional boot script not found. Continuing to boot normally
Bad Linux ARM zImage magic!
SOCFPGA_CYCLONE5#
Now I will a linux image Thanks a lot for your help
