drbarryh
Contributor
9 months agoAshling RISC Free IDE fails to download ELF file
Hello ALTERA NIOSV Experts, I have been trying to execute an application using a NIOSV CPU with the Ashling RISC Free IDE. The problem is that when trying to download the elf file to a MAX10 ALTERA ...
Rejeesh_Ashling
7 months agoHi,
The issue discuss both debug (which was related to antivirus) was and desing related items; could you brief the exact issue you are facing with USB Blaster II? Ashling RiscFree does support USB Blaster II and the debug should work.
Rejeesh
ponaudo
6 months agoHi Rajeesh,
Thank you for your fast reply.
I am currently using a USB Blaster I with Ashling RiscFree for Altera 25.3 and a Cyclone 10 GX FPGA. Programming the FPGA works without any problems.
The issue arises when I try to load the .elf to my NIOS V/m. I have the same "error in GDB launch sequence (no harts found)" and was wondering, if it is a blaster issue which may can be solved by using a USB Blaster II or III.
Best regards
