Ashling IDE scripted project creation
Seems you are passing the project path instead of workspace path; could you try "RiscFree.exe -data %CD%\sw_workspace" instead of "RiscFree.exe -data %CD%\..\sw_repo" ?
Okay yeah I'm very confused on how this command is supposed to work. "sw_repo" contains my the source code, the .cproject, .project, .settings I want to import. When I'm in the Ashling RiscFree GUI/IDE, I click file -> Import -> Existing Project, and then I point it to "sw_repo" and this works: it imports the code like I expect, project is shown in the project explorer tab, I can build/debug/etc.
In the cleaned state, sw_workspace is currently empty except for a .metadata folder.
As a test, I tried manually copying all my files from sw_repo into sw_workspace (so now sw_workspace contains .metadata, .project, .cproject, .settings, .c, .h), and then ran the command "RiscFree.exe -data %CD%\sw_workspace", but I got the exact same result: "There are no projects in your workspace"
- Rejeesh_Ashling6 months ago
Please note that I dropped a private message couple of days back requesting a screen-shared session to better understand your requirement and the exact issue you are facing. Could you respond based on your availability.
Rejeeh - BoonBengT_Altera6 months ago
Moderator
Hi sittinhawk,
I hope you’re doing well. I wanted to follow up and check if there are any remaining questions or concerns regarding this matter.
Please let us know if anything still needs clarification — we’re happy to assist further.
Thank you for your time, and we look forward to your feedback.
Best Wishes
BB
