20 years agoAnother USB blaster problem
Just arrived here, a USB blaster. Install driver, upload FPGA configuration data no problem. Then tried nios2-download to get the software into the system, but strange erro occurs. Then tried with byteblaster to get software into the system (like I did already for years). No problem. Here is the difference between the two : USB blaster :$ nios2-download safe.elf --cable 2 -g
Using cable "USB-Blaster ", device 1, instance 0x00
Pausing target processor: OK
Downloading 00100000 ( 2%)assertion "m_state == STATE_DEBUG" failed: file "nios2
debug.cpp", line 1695
Signal 6 and with byteblaster : $ nios2-download safe.elf --cable 1 -g
Using cable "ByteBlasterII ", device 1, instance 0x00
Pausing target processor: not responding.
Resetting and trying again: OK
Downloaded 181KB in 4.4s (41.1KB/s)
Verified OK
Starting processor at address 0x00100000 Any idea what to check? Stefaan4 Replies
Odds are that you have signal integrity issues, especially, if this is a custom board...
The fact that it works with a ByteBlaster II and not with the USB Blaster probably has to do with the speed at which data is traveling across the interface. The USB Blaster is quite a bit faster. It's my opinion that a board's JTAG chain is not clean until I can debug CPUs and run Signaltap II sessions, simultaneously, from within each of the FPGAs in my chain. There's help/advice available from the Altera website and this forum. Good luck! - slacker --- Quote Start --- originally posted by svhb@Oct 21 2005, 01:36 AM hello,just arrived here, a usb blaster. install driver, upload fpga configuration data no problem.
then tried nios2-download to get the software into the system, but strange erro occurs.
then tried with byteblaster to get software into the system (like i did already for years). no problem.
here is the difference between the two :
usb blaster :
$ nios2-download safe.elf --cable 2 -g using cable "usb-blaster ", device 1, instance 0x00 pausing target processor: ok downloading 00100000 ( 2%)assertion "m_state == state_debug" failed: file "nios2 debug.cpp", line 1695 signal 6and with byteblaster :
$ nios2-download safe.elf --cable 1 -g using cable "byteblasterii ", device 1, instance 0x00 pausing target processor: not responding. resetting and trying again: ok downloaded 181kb in 4.4s (41.1kb/s) verified ok starting processor at address 0x00100000any idea what to check?
stefaan
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=10499)</div> --- Quote End ---
Indeed, I looked for some inforamtaion about that, but why is configuring the device ok, and downloading sw not??
--- Quote Start --- originally posted by slacker+oct 22 2005, 02:04 am--><div class='quotetop'>quote (slacker @ oct 22 2005, 02:04 am)</div>--- quote start ---
odds are that you have signal integrity issues, especially, if this is a custom board...
the fact that it works with a byteblaster ii and not with the usb blaster probably has to do with the speed at which data is traveling across the interface. the usb blaster is quite a bit faster.
it's my opinion that a board's jtag chain is not clean until i can debug cpus and run signaltap ii sessions, simultaneously, from within each of the fpgas in my chain.
there's help/advice available from the altera website and this forum.
good luck!
- slacker
<!--quotebegin-svhb@Oct 21 2005, 01:36 AM hello,
usb blaster :
stefaan
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=10499)</div> --- Quote End --- <div align='right'><{post_snapback}> (index.php?act=findpost&pid=10518)</div> [/b] --- Quote End ---
Configuring the device is, for the most part, unidirectional, and likely slower than what download/debug/jtag_uart use. Successful configuration does not exonerate the JTAG chain...
- slacker - Altera_Forum
I've had similar problems in the past. My problem has been the jtag clock line. I had to cut the traces on both ends of the clock trace and add a jumper. Good luck.
George
