20 years agoAnother USB blaster problem
Hello, Just arrived here, a USB blaster. Install driver, upload FPGA configuration data no problem. Then tried nios2-download to get the software into the system, but strange erro occurs....
20 years agoOdds are that you have signal integrity issues, especially, if this is a custom board...
The fact that it works with a ByteBlaster II and not with the USB Blaster probably has to do with the speed at which data is traveling across the interface. The USB Blaster is quite a bit faster. It's my opinion that a board's JTAG chain is not clean until I can debug CPUs and run Signaltap II sessions, simultaneously, from within each of the FPGAs in my chain. There's help/advice available from the Altera website and this forum. Good luck! - slacker --- Quote Start --- originally posted by svhb@Oct 21 2005, 01:36 AM hello,
just arrived here, a usb blaster. install driver, upload fpga configuration data no problem.
then tried nios2-download to get the software into the system, but strange erro occurs.
then tried with byteblaster to get software into the system (like i did already for years). no problem.
here is the difference between the two :
usb blaster :
$ nios2-download safe.elf --cable 2 -g
using cable "usb-blaster ", device 1, instance 0x00
pausing target processor: ok
downloading 00100000 ( 2%)assertion "m_state == state_debug" failed: file "nios2
debug.cpp", line 1695
signal 6
and with byteblaster :
$ nios2-download safe.elf --cable 1 -g
using cable "byteblasterii ", device 1, instance 0x00
pausing target processor: not responding.
resetting and trying again: ok
downloaded 181kb in 4.4s (41.1kb/s)
verified ok
starting processor at address 0x00100000
any idea what to check?
stefaan
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=10499)</div> --- Quote End ---
