20 years agoAnother USB blaster problem
Hello, Just arrived here, a USB blaster. Install driver, upload FPGA configuration data no problem. Then tried nios2-download to get the software into the system, but strange erro occurs....
20 years agoIndeed, I looked for some inforamtaion about that, but why is configuring the device ok, and downloading sw not??
--- Quote Start --- originally posted by slacker+oct 22 2005, 02:04 am--><div class='quotetop'>quote (slacker @ oct 22 2005, 02:04 am)</div>--- quote start ---
odds are that you have signal integrity issues, especially, if this is a custom board...
the fact that it works with a byteblaster ii and not with the usb blaster probably has to do with the speed at which data is traveling across the interface. the usb blaster is quite a bit faster.
it's my opinion that a board's jtag chain is not clean until i can debug cpus and run signaltap ii sessions, simultaneously, from within each of the fpgas in my chain.
there's help/advice available from the altera website and this forum.
good luck!
- slacker
<!--quotebegin-svhb@Oct 21 2005, 01:36 AM hello,
just arrived here, a usb blaster. install driver, upload fpga configuration data no problem.
then tried nios2-download to get the software into the system, but strange erro occurs.
then tried with byteblaster to get software into the system (like i did already for years). no problem.
here is the difference between the two :
usb blaster :
$ nios2-download safe.elf --cable 2 -g
using cable "usb-blaster ", device 1, instance 0x00
pausing target processor: ok
downloading 00100000 ( 2%)assertion "m_state == state_debug" failed: file "nios2
debug.cpp", line 1695
signal 6
and with byteblaster :
$ nios2-download safe.elf --cable 1 -g
using cable "byteblasterii ", device 1, instance 0x00
pausing target processor: not responding.
resetting and trying again: ok
downloaded 181kb in 4.4s (41.1kb/s)
verified ok
starting processor at address 0x00100000
any idea what to check?
stefaan
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=10499)</div> --- Quote End --- <div align='right'><{post_snapback}> (index.php?act=findpost&pid=10518)</div> [/b] --- Quote End ---
