21 years agoAbout the SDRAM clock delay compensate.
In the reference design of Nios I/II, a sdram_pll is used to do a -72 degree compensate for the SDRAM clock
Why -72 degree? How to calculate it? Now I want to design a new boad with Nios II in a cyclone, but the compensate of the SDRAM clock pains me, I do not know how to handle the SDRAM clock. Can someone give me some hints? http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/unsure.gif http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/blink.gif2 Replies
After checking the development board(cyclone) schematic, I found that the Extport of the connector_pll---pld_clockout drives a clock buffer chip(PI49FCT3805) and the PI49FCT3805's output(pld_clkfb) feeds the sdram_pll. This clock signal then be shifted -72degree to drive the sdram(sdram_clk).
Why? In my opinion, there are multi devices on the development board use the clk signal of the Nios CPU, the connector_pll just does this work----- export the Nios clk signal to the clock buffer(PI49FCT3805). Devices like the config_controller CPLD will use the buffered clock. One of the buffered clock signal then goes into the FPGA to feed the sdram_pll because the cyclone pll cannot be fed by a internal clock signal, i.e it's input must comes outside. After shifting some degree, the buffered signal then goes out of the FPGA to drive the SDRAM. Maybe the -72 degree is the compenstation of the round-trip of the clk. Am I right? crystal---->connector_pll----->PI49FCT3805(buffer)----->sdram_pll----->sdram - Altera_Forum
Remy,
Your analysis is correct. On Stratix/S-II we do not have this restriction and you'll see that we use one PLL, with a zero-shift system clock and shifted SDRAM clock output. Your question about why: This has been discussed before on this forum and on comp.arch.fpga.. if you search for 'sdram pll' or something similar I think you'll find the details. You should note that the phase shift is *not* derived in degrees phase; its measured in nanoseconds and put into the PLL wizard which then calculates the phase shift for your desired clock speed. The shift is a constant time per board design, varying on trace lengths to SDRAM.
