21 years agoAbout the SDRAM clock delay compensate.
In the reference design of Nios I/II, a sdram_pll is used to do a -72 degree compensate for the SDRAM clock Why -72 degree? How to calculate it? Now I want to design a new boad with Nios II in ...
21 years agoRemy,
Your analysis is correct. On Stratix/S-II we do not have this restriction and you'll see that we use one PLL, with a zero-shift system clock and shifted SDRAM clock output. Your question about why: This has been discussed before on this forum and on comp.arch.fpga.. if you search for 'sdram pll' or something similar I think you'll find the details. You should note that the phase shift is *not* derived in degrees phase; its measured in nanoseconds and put into the PLL wizard which then calculates the phase shift for your desired clock speed. The shift is a constant time per board design, varying on trace lengths to SDRAM.
