19 years ago
About BinaryToolchain
i followed the passage on niosWiki:
binarytoolchain (http://www.niosforum.com/pages/forum.php?cat_id=5)
i run the command in terminal:
su -# your root passwd
tar jxf /home/hippo/download/nios2gcc.tar.bz2 -C /
exit
after that, i found the cross gcc tools in "/opt/nios2", then i opened the file".bash_profile" and added "PATH=$PATH:/opt/nios2/bin:$HOME/bin" into it.
but when i run the command "nios2-linux-uclibc-gcc -v", the terminal showed followed error:
"bash:nios2-linux-uclibc-gcc -v : can't find the command",
i hope someone can help me! thanks
    after you change the .bashprofile, you need to logout and login again.
    --- Quote Start ---
    <div align='right'><{post_snapback}> (index.php?act=findpost&pid=22782)
    --- quote end ---
    --- Quote End ---
    thanks, hippo.but i still can&#39;t run the command "nios2-linux-uclibc-gcc -v" after logining again. and my .bash_profile&#39;s content is :
    ======================================# ~/.bash_profile: executed by bash(1) for login shells.# see /usr/share/doc/bash/examples/startup-files for examples.# the files are located in the bash-doc package.
    # the default umask is set in /etc/login.defs# umask 022
    # include .bashrc if it exists
    if [ -f ~/.bashrc ]; then
    . ~/.bashrc
    fi
    # set PATH so it includes user&#39;s private bin if it exists
    if [ -d ~/bin ] ; then
    PATH=~/bin:"${PATH}"
    fi
    is there any problem whit it? hope you can help me ,thanks!
    by the way, my linux-OS is Ubuntu6.1
    i have solved the problem, i setted the PATH in the file ".bashrc", adding following text:# ###
    export PATH="$PATH:/opt/nios2/bin:$HOME/bin"# ###
    then i can run the command "nios2-linux-uclibc-gcc -v ".
    i think the PATH settings vary from different linux OS, maybe! http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/smile.gif
