19 years agoAbout BinaryToolchain
i followed the passage on niosWiki: binarytoolchain (http://www.niosforum.com/pages/forum.php?cat_id=5) i run the command in terminal: ********************* su -# your root passwd tar...
19 years ago --- Quote Start --- originally posted by hippo@Apr 4 2007, 12:16 AM after you change the .bashprofile, you need to logout and login again.
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=22782)
--- quote end ---
--- Quote End --- thanks, hippo.but i still can't run the command "nios2-linux-uclibc-gcc -v" after logining again. and my .bash_profile's content is : ======================================# ~/.bash_profile: executed by bash(1) for login shells.# see /usr/share/doc/bash/examples/startup-files for examples.# the files are located in the bash-doc package. # the default umask is set in /etc/login.defs# umask 022 # include .bashrc if it exists if [ -f ~/.bashrc ]; then . ~/.bashrc fi # set PATH so it includes user's private bin if it exists if [ -d ~/bin ] ; then PATH=~/bin:"${PATH}" fi PATH=$PATH:/opt/nios2/bin:$HOME/bin ======================================= is there any problem whit it? hope you can help me ,thanks! by the way, my linux-OS is Ubuntu6.1
