19 years agoAbout BinaryToolchain
i followed the passage on niosWiki: binarytoolchain (http://www.niosforum.com/pages/forum.php?cat_id=5) i run the command in terminal: ********************* su -# your root passwd tar...
19 years agoi have solved the problem, i setted the PATH in the file ".bashrc", adding following text:# ###
export PATH="$PATH:/opt/nios2/bin:$HOME/bin"# ### then i can run the command "nios2-linux-uclibc-gcc -v ". i think the PATH settings vary from different linux OS, maybe! http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/smile.gif
