A_en is 'X' problems
Hi there,
i have wrote some VHDL program in QuartusII (10.1)as custom instruction for NIOSII and implemented a SOPC system with Nios II. Then i go to the EDA (eclipse) generate a hallo world program and run it in Modelsim(6.4b). And everything is ok untill this error pop up in modelsim: # 314830 ns: ERROR: NIOS_test_bench/A_en is 'x'# ** Failure: VHDL STOP# Time: 314830 ns Iteration: 1 Process: /test_bench/dut/the_nios/the_nios_test_bench/#MERGED#line__877,842,786,768,731,713,695,677,641,623,605,587,531,494 File: /home/Desktop/dct_transform/NIOS_test_bench.vhd# Break in Architecture europa at /home/Desktop/dct_transform/NIOS_test_bench.vhd line 598 and the relative Code is generated automatically by SOPC builder : process (clk) VARIABLE write_line5 : line; begin if clk'event and clk = '1' then if std_logic'(reset_n) = '1' then if is_x(std_ulogic(A_en)) then write(write_line5, now); write(write_line5, string'(": ")); write(write_line5, string'("ERROR: NIOS_test_bench/A_en is 'x'")); write(output, write_line5.all & CR); deallocate (write_line5); assert false report "VHDL STOP" severity failure; end if; end if; end if; end process; ok, please help!!!:(17 Replies
Forcing is a little extreme here. It is usualy best just to initialise the signals properly in the testbench.
It works for me. Basically there is no clock or reset assertion unless I set them up myself.
How do you initialise them in the testbench? - Altera_Forum
For VHDL, you give them an Initial value:
signal clk : std_logic := '0'; - Altera_Forum
Oh... that's not what I meant. :)
I need to set the the clock toggling high and low and set the reset high to start with and then set it low.... Otherwise I get the A_en is 'X' problem. I didn't have this issue with SOPC.... I could run my simulations after entering the 's' macro into modelsim.... For some reason I have to setup my clocks and reset while simulating from Qsys... - Altera_Forum
Okay I found the real problem and it was down to me. For some reason I had the jtag_debug_module_reset connected to the other reset lines. As soon as I disconnected this it ran correctly from the BFM.
Now I have the Clock Source driving the clk and clk_reset to the rest of the system and the error is gone. - Altera_Forum
This sounds like a bug to me if I understood your connectivity. You should be able to connect the JTAG debug module reset request to the Nios II processor. If you have the simulation up can you check what state that reset request is in, I'm suspecting it's driven to 'X' and causing this problem.
I had the JTAG debug module reset connected to all components' reset. I will check when I have a sec to do so....
