15 years agoA_en is 'X' problems
Hi there, i have wrote some VHDL program in QuartusII (10.1)as custom instruction for NIOSII and implemented a SOPC system with Nios II. Then i go to the EDA (eclipse) generate a hallo world progr...
13 years agoOh... that's not what I meant. :)
I need to set the the clock toggling high and low and set the reset high to start with and then set it low.... Otherwise I get the A_en is 'X' problem. I didn't have this issue with SOPC.... I could run my simulations after entering the 's' macro into modelsim.... For some reason I have to setup my clocks and reset while simulating from Qsys...
