21 years ago
"__attribute__((section(".SDRAM")))" problem
Hi all,
I'm trying to allocate a buffer in SDRAM using the declaration:
volatile int buff1_app[1280] __attribute__((section(".SDRAM")));
in SOPC i've defined a SDRAM controller named "sdram".
I've set the reset address of my system in flash, exception address,program and data memory resides in SDRAM. When i compile i receive the error message:
*** [ext_flash.flash] Error 5
H320_prove Error 5-mag-2005 12.29.36 - * *** [ext_flash.flash] Error 5 Boot copier overlaps data in flash H320_prove line 0 Error
5-mag-2005 12.29.36 - * Boot copier overlaps data in flash Error generating Flash file, exiting H320_prove line 0
if i define the buffer:
volatile int buff1_app[1280] ;
everything works fine.
Any suggestion?
