JohnT_Altera
7 years agoHi,
You are not suppose to use RBF file. Please generate RPD file which is the correct file for Active Serial configuration. You can generate the RPD file when you convert SOF to POF file with the "Generate RPD file" tick.
HBhat2
Contributor
5 years agoHi, can any one tell the how to update remote fpga ip and how to configure that Ip to generic serial flash interface IP. if possible update the refernce design example and document
Thank You
ashwini
