PJancso
7 years agoWhich programming file format should be used for partial programming of serial flash with remote update feature?
My goal is to implement remote update feature. The Cyclone V GX FPGA is connected to EPCQ256 in ASx4 mode, in which I store factory image at 0x0 address and an application image at 0x800000 address. ...
- 7 years agoHi, You are not suppose to use RBF file. Please generate RPD file which is the correct file for Active Serial configuration. You can generate the RPD file when you convert SOF to POF file with the "Generate RPD file" tick.
JohnT_Altera
7 years agoHi,
- HBhat25 years ago
Contributor
Hi, can any one tell the how to update remote fpga ip and how to configure that Ip to generic serial flash interface IP. if possible update the refernce design example and document
Thank You
ashwini
