where to find testbench with Scalable Switch Intel® FPGA IP for PCI Express?
There is only a sim top file under switch_ed/sim directory,no testbench file.
can you snapshot?
Hi Wilson,
If you are refer to the xxx_tb.v file you can refer to switch_ed.v
Let me know if I am not answering your question or I miss-understand anything.
Wincent_Altera
- wilson19771 year ago
There are two demux_1stage_pipeline code under switch_user_logic/demux.v .The upper parts are commented.The lower parts are opened.
I want to use the upper parts code(commented). can it work?
// | single buffered pipeline stage
//module demux_1stage_pipeline
// #( parameter PAYLOAD_WIDTH = 8 )
// ( input clk,
// input reset_n,
// output reg in_ready,
// input in_valid,
// input [PAYLOAD_WIDTH-1:0] in_payload,
// input out_ready,
// output reg out_valid,
// output reg [PAYLOAD_WIDTH-1:0] out_payload
// reg in_ready1;
// always @* begin
// in_ready = out_ready || ~out_valid;
// // in_ready = in_ready1;
// // if (!out_ready)
// // in_ready = 0;
// end
// always @ (posedge clk) begin
// if (!reset_n) begin
// in_ready1 <= 0;
// out_valid <= 0;
// out_payload <= 0;
// end else begin
// in_ready1 <= out_ready || !out_valid;
// if (in_valid) begin
// out_valid <= 1;
// end else if (out_ready) begin
// out_valid <= 0;
// end
// if(in_valid && in_ready) begin
// out_payload <= in_payload;
// end
// end // else: !if(!reset_n)
// end // always @ (negedge reset_n, posedge clk)
//endmodule //
( input clk,
input reset_n,
input in_valid,
input out_ready,
);always @ (posedge clk or negedge reset_n)
begin
if (!reset_n)
begin
out_valid <= 0;
out_payload <= 0;
in_ready <= 0;
end
else
begin
in_ready <= out_ready;
out_valid <= in_valid;
end
end
endmodule//- Wincent_Altera1 year ago
Hi Wilson,
Is there any special reason you need to used the commended part ?
Just try to understand more and check if the application is ideal or not.
>> Well, as I go through the code, the (commented) code seen to be likely more robust in handling backpressure and ensuring data integrity in a pipeline scenario.
>> Meanwhile for the (uncommented) code simplifies the logic by directly mapping input signals to output signals
>> Answering your question, yes you can - depends on your application and needs. As long as the compilation PASS , it shall be no problem.
WIncent_Altera- wilson19771 year ago
The upper slice style has a buffer.
