13 years ago
What is the major difference betweet 3 differnt ways of creating a DCFIFO?
What is the major difference betweet 3 different ways of creating a DCFIFO?
1). by MegaWizard plug-in manager
2). by a Symbol in BDF editor
3). by a Qsys
In which case which one should be used?
Which one is less buggy?
    They all create a DC fifo that work identically (its the same code underneath). But you cannot simulate 2). Avoid BDF editor like the plague.
    1) Generates a DCFIFO component with a "basic" interface, to be used directly in VHDL/HDL code.
    2) Does the the same as 1 and generates a component to be used in BDF.
    3) Generated a DCFIFO component with an Avalon-ST interface, to be used as part of a Qsys system.
    So, you use
    3) when you need a DCFIFO in a Qsys system
    2) when you need a DCFIFO for a piece of logic you're creating using BDF. And you should avoid BDF at all if possible.
    1) when you need a DCFIFO for a piece of logic you're creating using VHDL/Verilog.
