VVP Protocol Converter Not work
Hi Wincent_Altera ,
I instantiate a VVP Chroma ReSampler by converter YCC 422 to 444.
For unknown reason, the CRS did not set the Tready even after updating the registers.
And I did not see the Tready raised high after reset.
This behavior is not as mentioned in UG page 21..
Any suggestion for me to check.
Thank you.
- JLee252 months ago
Contributor
Hi Wincent_Altera ,
I have update on this issue..
I instantiate IP core one by one and it's fine except the VVP protocol converter, LITE to Avalon Stream..
For unknown reason, the Sink side ready always kept now..
Thanks for supporting.
- Wincent_Altera2 months ago
Hi JLee25 ,
Based on what you provided,
most likely remaining cause is that the MM writes are not reaching the compiled Protocol Converter instance correctly—
for example, wrong base address/offset, incorrect byte addressing, or an inactive control-interface clock/reset domain.
Can you please check from there ?
Wincent_Altera
