JLee25
Contributor
3 months agoVVP Protocol Converter Not work
Hello, I am looking for how to use the VVP protocol converter, by converting Altera Stream Video Lite to Avalon Streaming Video. I generate a simple pipeline with Protocol Converter to Frame Bu...
JLee25
Contributor
3 months agoHi Wincent_Altera ,
I checked the point you mentioned about the missing MM control interface on GUI using the "UDX 3D LUT" example.
And quite confirmed that this is what you will see on the platform designer.
Below is the capture of the UDX design
And I am quite sure that I can access the settings even the MM interface is not enabled...
And I expect to see the TREADY signal after IP core reset and write proper configuration values per VVP UG chap 3.
But I don't know this is not happened for components like frame buffer, 1D LUT...
