16 years agoVIP FrameBuffer - How do you think it is accessing the SDRAM?
Hi! I am thinking about FrameBuffer Core Altera provides. In the VIP User Guide it is explained clearly, how the FB is working, with the concepts of dual and triple buffering. What I don't...
16 years agoHi Kevin, I can't tell to much about the system, because it will be my bachelor thesis and that could bring some trouble up. The problem I was fighting is to write 32bit to the sdram and read 32bit with both 65Mhz, while the sdram only runs with 100Mhz. So your suggestion brought me to a whole new idea, I had not found on my own. While increasing the datawidth it could be possible that I can process the data without problems. I calculated and programmed already a bit and the idea is great, but I did not have a working solution, yet. But I am very thankful, that you gave me this impulse. Thanks.
Yours, Peter.
