16 years agoVIP Control is Mutilating my Image!!!
Hello All, I have an interesting problem. I've managed to put together a video processing path: cvi->scaler->frame buf->cvo Which works reasonably well scaling SXGA to SVGA for displa...
16 years agoBrent,
If you think you've found a bug, we need to report it up through the ranks. Actually, the CVI source code is accessible. Look in the "db" directory of your project. You should see a file named "alt_vip_Vid2IS.v". This is the source code for the CVI. Can you grab that file from both your 9.0 and 9.1 projects and send them to me? I can then see if I can find the problem and report it. You can also file a service request if you think you've found something. Jake
