16 years agoVIP Control is Mutilating my Image!!!
Hello All, I have an interesting problem. I've managed to put together a video processing path: cvi->scaler->frame buf->cvo Which works reasonably well scaling SXGA to SVGA for displa...
16 years agoHere is a screengrab from SignalTap. FYI, my path has 3 colour planes in parallel 4bits wide each. I tapped the input to the scaler, which below the CVI in the system. Looks like the control packets are ok:
- width = 0x04F9= 1273 pixels which is acceptable - (but should be 1280 strictly) - height = 0x0400 = 1024 lines which is perfect - interlacing field = 0x2, progressive which is correct. The packets are consistent, but only occur once, when the VIP is turned on, shouldn't these occur more frequently? Or does a control packet only occur when there is a change in settings? I'm going to re-introduce the control port on the scaler, then tap it's output, then successively each downstream.
