16 years agoVideo processing demonstration.
Hello! I already posted a similar question in another subforum but didn't succeed to get what I wanted to know. Maybe because the first post was too long. So this time, let's make it simple...
16 years agoThere is a pre-built SOF/ELF combination that should work. It will also work to re-compile just the software for your own experimentation. In order to get the whole thing functioning properly, there are some VIP-related constraints that need to be understood/applied prior to QII compile. As far as I know, this is not done automagically and/or there are errors in the existing constraints.
For my needs, it was enough to just muck with the software side of things, so I didn't dig too deeply into the hardware side. Cheers, -slacker
