16 years agoVideo IP
Hello I will make a camera tracking system on SopC on a Cyclone II DE2 EP2C35 Board. To begin I will start with a simply Video communication, I try wit this IP-Blocks: - cpu - on-ch...
16 years agoWell, I dont' know your video and components requirements, but I would try to use the clocked video output instead the VGA blocks you are using right now..
Then I think you should use different clocks for video input and video pipeline. about your frame buffer, what kind of ram are you using? Are you sure you have enough bandwidth in your system?
