16 years agoVideo IP
Hello I will make a camera tracking system on SopC on a Cyclone II DE2 EP2C35 Board. To begin I will start with a simply Video communication, I try wit this IP-Blocks: - cpu - on-ch...
16 years agofile:///C:/Users/ANTONI%7E1/AppData/Local/Temp/moz-screenshot.png file:///C:/Users/ANTONI%7E1/AppData/Local/Temp/moz-screenshot-1.png I try to make a circuit below:
see attachment I thing that the pixel-converter and the video-sync- generator must not implement in the circuit. Is that right? Is the functionality of the frame buffer, to store frame in the sdram? How can I store frame without use a frame buffer? I assume that i must convert YCbCr to RGB first, before i can make video image proccessing, example a easy black point on white surface tracking with camera? Before i begin with the camera tracking i will mafe first a easy video circuit on vga monitor... Thanks for any tipps...:)
