16 years agoVHDL-Code with Avalon Bus Interface-/ and VHDL-Video-System-Interface-Ports
Hello I provided the following ENTITY. Can I actually provide a IP, which some haven connectivity with the Avalon bus, as well as haven as down descriptive for the VHDL_Detector, which is not c...
16 years agothanks you from help. But now I make the avalon bus otherwise.
I changed the reg.h file. I use only a Register with only a address. when the x/y coordinate are ready to read, I send a Interrupt via coe_oCOORD_IRQ to PIO-Interface. This Methode works well. But when I incontre other problems, I post it for any good suggest from you... Antonio
