16 years agoVHDL-Code with Avalon Bus Interface-/ and VHDL-Video-System-Interface-Ports
Hello I provided the following ENTITY. Can I actually provide a IP, which some haven connectivity with the Avalon bus, as well as haven as down descriptive for the VHDL_Detector, which is not c...
16 years agoyou don't want to use the avs_dataavailable signal. Either create an interrupt that is triggered on the new state, or create a register you can read/poll that has the status of the new coordinate state that can be cleared when you read it. i have never used the dataavailable signal, but if you were to use the avalone bus to indicate when data was ready to read you would have to issue a read and the bus would hang until the new coordinate was present, which is most likely not what you want.
Kevin
