16 years agoVHDL-Code with Avalon Bus Interface-/ and VHDL-Video-System-Interface-Ports
Hello I provided the following ENTITY. Can I actually provide a IP, which some haven connectivity with the Avalon bus, as well as haven as down descriptive for the VHDL_Detector, which is not c...
16 years agoIn general, you have part of your component that attaches to the sopc system via some avalon style bus, and then you have the other part that are defined in the *_hw.tcl file as conduits. Just define everything you want to connect not in the sopc system as conduits and hook them up outside of the sopc generated block. Give it a try and see what happens.
