Using VIP suite with Triple Speed Ethernet (TSE)
Hallo,
i am working on a small Project with the Triple Speed Ethernet and VIP suite (Video and Image processing Suite). I need to send the data from the Testpattern Generator IP via Ethernet and show them in VLC Player. Did anyone try to combine such two IPs ? I searched a lot to find any example in QSYS to start with and didnt find any. Thanks a lot for any help ! Jalayan12 Replies
Hi first of all you have to decide the transport-protocol, such as HTTP or UDP.
Secondly you have to decide maybe the compression algorithm such as JPEG, H264, things like that. If you have all of that maybe start to communicate first with a Webbrowser. (Shown in Ethernet-Ref-Design for Cyclone III Board) If that works, you could start to communicate with some "fixed" images. If that works, try to make it with the live-images... I hope that helps... - Altera_Forum
Hey Taz1984,
Thanks for answering the Question, i need to transport the data with RTP. Do u Know any good Library for UCOS ? Greetings Jalayan - Altera_Forum
Sorry, we implemented it based on the LWIP-Stack as baremetal-NIOS-program
ok, so you're saying if i use the LWIP-Stack it will be easier to implement RTP ?
where can i get the (HAL) library for RTP if i may ask ? Many Thanks ! - Altera_Forum
There is no library available I think, you have to implement it against the specification...
Try to use the VLC-Player and wireshark to enforce the correct protocol. With this two you can send a stream from VLC first and receive the packets via wireshark... After that you should know more about the headers of udp and rtp... - Altera_Forum
i successfully recieved Datenpakete from VLC Player with UDP Header. I resended those Datenpakets to an another VLC Player and i was able to see the Video (with a very bad quality). I used the Iniche Stack
i want to move forward and start receiving the RTP Pakets from VLC Player. Do u have any Examples or links or code that may help ? Thanks ! Jalayan - Altera_Forum
maybe the lwip reference design for the nios which is based on the tse design-example for the CIII120 Dev-Board
can i bother u and give me the Link ?
if u implemeted RTP can u show some of your code ? Thanks ! Jalayan - Altera_Forum
TSE Design-Example [1].
LWIP [2] & [3] [1] http://www.altera.com/support/examples/nios2/exm-net-std-de.html [2] http://www.altera.co.jp/literature/tt/tt_nios2_lwip_tutorial.pdf [3] www.google.com -> search for "lwip nios" The RTP is an additional Protocol based on top of udp. You should be able to implement this state-machine on your own if you go through the lwip-stack... We are not here to solve the problems of the others, but to guide to the right direction... In this way everybody is able to learn something... =) - Altera_Forum
Thanks for the Links !
i reviewed the Lwip Designs, but im going to stick with the iniche Stack. but i didnt understand how can u send RGB data to the iniche Stack or Lwip Stack ? dont u need to need to give each Paket comming from the Testpattern generator IP (from the VIP Suite) an UDP Header before reaching the Iniche Stack or LwIP inorder to be capable sending these pakets again ? In case recieving the Pakets from the Triple speed Ethernet, the data pakets will contain an UDP Paket, but not if u recieve them them from the Testpattern generator. Thanks again for answering my questions ! Jalayan
