11 years agoUsing VIP suite with Triple Speed Ethernet (TSE)
Hallo, i am working on a small Project with the Triple Speed Ethernet and VIP suite (Video and Image processing Suite). I need to send the data from the Testpattern Generator IP via Et...
11 years agoThere is no library available I think, you have to implement it against the specification...
Try to use the VLC-Player and wireshark to enforce the correct protocol. With this two you can send a stream from VLC first and receive the packets via wireshark... After that you should know more about the headers of udp and rtp...
